Flowbench for sale (Updated)
resbum
Post by resbum »
This is a homemade flow bench located in Eaton, Ohio.
It was patterned from some great info from these websites;
http://performancetrends.com/ez_flow_system.htm
http://www.flowbenchtech.com/plans.html
http://speedtalk.com/forum/viewtopic.ph ... 8&start=15
http://www.popularhotrodding.com/tech/0 ... ewall.html
http://www.audietech.com/flow-quik/what-it-is.html
There is a pair of Amtek vacuum motors that I intended to use for small jobs.
http://www.ametekfsm.com/Vac-Blower/Through-Flow.aspx
There is a 4.5 hp 3 phase 220V blower I intended to use for larger jobs. It is a VFC600A-7W Max CFM 206 @ 118" H20
http://www.carymfg.com/pdfs/fuji-electric-catalog.pdf
Includes a heavy duty cut-off switch and an extra Dwyer Differential Pressure gauge.
****NEW ADDITION****
I have a brand new ROTARY PHASE CONVERTER Model (R5).
It is used to allow a 3 phase motor to operate on single phase
http://phase-a-matic.com/RotaryDescription.htm
http://phase-a-matic.com/PDF/RPL.pdf
Instrumentation includes;
Meriam Inclined Manometer http://www.testequipmentdepot.com/meria ... clined.htm
Digital Dwyer Manometer http://www.dwyer-inst.com/Product/Press ... /Series477
Dwyer Differential pressure gauge
http://www.dwyer-inst.com/Product/Press ... ModelChart
There is an access port to reach inside and select different size venturis .
I will give you all the tech-data I have on venturis, blowers and instruments.
It needs very little plumbing to finish it and the websites have tons of info.
I have a TSI Digital Mass flow-meter installed.
http://www.tsi.com/uploadedFiles/_Site_ ... -print.pdf
Asking $1100
The cost of the brand new rotary phase converter is $900 so you are getting the rest of the stuff for $200
This is extremely heavy (hundreds of pounds) so bring some help.
Steven Parker
resbum@gmail.com
