What is the formula for converting CFM pressures
Place to add formulas. If you post a formula please make sure your abbreviations are spelled out so it avoids a lot of follow-up postings. I know a lot of abbreviations are common or taken to be common knowledge. Please be sure to checkout the new FAQ of common abbreviations.
Please post formulas in separate topics, do not add formulas to someone else's post unless it relates to the original post. Also in the topic line make a note of what your posted formula is about . Thanks
tafeteacher
Post by tafeteacher »
Hi guys
I'm chasing the formula for converting flow at one pressure to another.
For example, let's say I have 100CFM@10" and I want to display it as flow@28". Does anyone know the conversion formula?
Thanks in advance
86rocco
Re: What is the formula for converting CFM pressures
Post by 86rocco »
Flow is proportional to the square root of the pressure difference so to convert from 10" to 28" you would multiply by √(28/10)=1.673. However, this is a best case scenario, bear in mind that different pressures mean different air speeds and higher speeds can sometimes induce turbulence which can effect flow so the conversion from one pressure to another is not always so straight forward.
tafeteacher
Thanks for that. Exactly what I was after!!
