Curtain Area to Valve Area Convergence Intake Valve Lift
Place to add formulas. If you post a formula please make sure your abbreviations are spelled out so it avoids a lot of follow-up postings. I know a lot of abbreviations are common or taken to be common knowledge. Please be sure to checkout the new FAQ of common abbreviations.
Please post formulas in separate topics, do not add formulas to someone else's post unless it relates to the original post. Also in the topic line make a note of what your posted formula is about . Thanks
hdwgfx
Re: Curtain Area to Valve Area Convergence Intake Valve Lift
Post by hdwgfx »
http://speedtalk.com/forum/viewtopic.ph ... 21&start=0
Postby maxracesoftware » Wed Jan 19, 2005 3:42 am
My first question is how do I reconcile my development experience, which leads me to believe that the optimum intake camshaft lift is 30% of the OD of the intake valve , with others (very informed others at that) suggesting lifts between 38% to 43% of intake OD. Is it simply the difference between a two valve head and a four valve head? Or are there are factors in play?
====== Intake Valve L/D Ratios ======
.37 % to .42 % Lift/Diameter Ratio for 2-Valve Heads
you would reduce the L/D Ratios by approx .916 PerCent to =>
.33892 to .38472 for all out max effort DragRacing type Cylinder Heads with 4 Valves
a good Street/Strip/Bracket Racing recommended L/D Ratio = .250 to .2844
also minimum recommended OEM L/D Ratios
for 4-Valve Heads would be approx .184 for pure street applications
for 2- Valve Heads = .201
and the Curtain and Valve Areas are equal at .25 L/D Ratio
regardless to whether 2 or 4 valves .
Meaux Racing Heads
MaxRace Software
PipeMax and ET_Analyst for DragRacers
http://www.maxracesoftware.com
http://maxracesoftware.com/bulletinboard/index.php
david
Faith/Desire/Tenacity NOTW
