It is currently Fri Apr 20, 2018 2:49 am
Reply to topic  [ 2 posts ]
 Inches Pressure into PSI
Does 40" mean 40 inches water pressure.
If so when I convert this to bar then psi,that is only 0.14PSI
The digital manometers online stop reading anything above 2.0psi.
So any of those digital manometers will do?
Sun Jun 04, 2017 4:20 am
An easy way to remember, 28 inches is very close to 1 Psi.
http://www.kylesconverter.com/pressure/inches-of-water-to-pounds-per-square-inch
Yes, forty inches of pressure means forty inch column of water in a manometer tube.
Two psi will get you up to about 55 inches which will be fine for a flow bench..
Sun Jun 04, 2017 7:35 pm
