Flow bench head stand how can i make one?
drifter
Post by drifter »
I just picked sf100 bench looks the same as a sf110 im not sure what the difference is.It did not come with the plexiglass table stand dose anyone have any pics of how they made up something to mount heads on mostly sb chevy for now
Hotz
Re: Flow bench head stand how can i make one?
Post by Hotz »
Welcome.
I did not understand exactly what you need.
But I believe that's it.
http://ultimateaircooled.com/tools/1149 ... stion.html
drifter
Post by drifter »
Yes thats what i need does anyone have a cheap way that i can build my own? Or are there any forsale anywhere?
Hotz
Post by Hotz »
You can make MDF or similar. and using a tube with a diameter that you need ... The demension take based on the cylinder head and the base of the SF.
I believe it is very simple ... good luck.
RACEPUMPER
Post by RACEPUMPER »
Basically your head stand or adapter needs to be the same size as your bore to shroud ( or restrict ) your valves the correct amount. The general idea is to have the height dimension equal to your stroke or longer. The bore diameter is crucial to your testing, where as your height doesn't alter the readings too much
Hotz
Post by Hotz »
In this video of a DIY PTS FB you can see better.
As Jim said you must have the hole diameter equal or approximate diameter of the cylinder of your engine
I particularly want to build my media with the Course and diameter identical to the engine design for testing the cylinder head.
A drawing I did.
by mop5ter.
