Newbie Question
bales
Newbie Question
Post by bales »
My use of the flowbench I plan to build will test heads for small c.i . 3 cyl engine approx 1.3 ltre or 71 ci. specifically. What will be the motor requirements for this project 120 0r 240 volt and how many. Any recommendations.
Thank you.
Re: Newbie Question
Bales, are you planning on building the PTS plans?
What is the HP range of the engine?
bales
Re: Newbie Question
Post by bales »
Yes I am I have purchased plans..hp when finish expected be 280 to 300.
Re: Newbie Question
I guess is that this is a Super/Turbo charged engine or something running 12 to 15,000 RPM with multiple valves per cylinder.
300 Hp / 3 = 100 / .27 = 370 CFM air requirement @ 28" a tall order for naturally exasperated so you will need to build a bench with access to 240VAC, since you posted 120/240 i assume you are in the US? which should not be an issue. All this said you will need a minimum 6 good motors to be able to flow these kind of numbers on a single internal plate.
bales
Re: Newbie Question
Post by bales »
Thanks Rick ,it will be turbocharged. I am looking for 240 volts i am looking for a set of six.
