PTS Universal Valve Opening Fixture
Posted: Fri Sep 19, 2014 7:33 pm
Plan to add this to the PTS Parts list in the very near future, still working out pricing. Will be limited quantities in stock at any given time.
Overall length of rails is 22", might offer shorter rails for smaller head combinations? Height of center block is 4". Finish will be raw aluminum, sorry no fancy anodizing keeps the cost down.
Re: PTS Universal Valve Opening Fixture
Posted: Fri Sep 19, 2014 8:15 pm
by Darcy R
Have you determined what the price would be?
Have you, or other members considered how this could be set up to open 2 valves of a 4 valve per cylinder head. ...some sort of add-on accessory perhaps?
Posted: Fri Sep 19, 2014 10:28 pm
Darcy R wrote:Have you determined what the price would be?
I just finished this one up today so I have to sit down this weekend and figure my time and material pricing.
Nothing on 2 or 4 valve setups but I have seen someone else's setup online where they had an add-on bracket so looks like something could be made? I'm open for ideas.
Also saw they have an add-on bracket to use on center valve cover bolts, I do not work with that style of heads so I'm at a loss for dimensions to design a bracket. I'm open to suggestions?
Posted: Sat Sep 20, 2014 10:51 am
by Hotz
Excellent work, a configuration to open two valves seem easy to later add.
Posted: Sat Sep 20, 2014 1:58 pm
Bruce, you may want to offer two different pitch opener threads the 1/4-20 and M6-1.0 for the metric crowd. :-)
Posted: Sat Sep 20, 2014 4:03 pm
Can you use it with heads that have canted valves like BBC ??
Very nice workmen ship Bruce :)
Posted: Sat Sep 20, 2014 8:34 pm
Malvin wrote:Can you use it with heads that have canted valves like BBC ??
To be honest . . . couldn't tell you if it would work. I pretty much reverse engineered the designs already on the market with my own changes to suit my machining equipment. Want to try it out for me? The one pictured is headed out to OZ Land this week but I have a second one I made for my own reference/use. The rails on that one are only 18" till I get some more rail material.
Thanks I'm pretty happy with how it turned out!
Posted: Sat Sep 20, 2014 8:45 pm
Yes send it up! :) I have a few BBC heads here plus a set of Spread port BBC that are 18ยบ
Posted: Tue Oct 07, 2014 7:31 am
Price will be $375 for the basic setup. I'm not ready to start mass producing these just yet and do not have any just sitting on the shelf right now so delivery will be sporadic for sometime.
I'm looking into the Center Valve Cover attachment brackets as well as shorter and longer main rails so price might be adjusted along the way.
The basic unit will come with ~22" rails
Posted: Tue Oct 14, 2014 9:21 am
by RVG440
Yes it does fit splayed valve heads. BBC,sb2,P7 etc. Had a quick look once I got it. I have a set of BRODIX BBC going on the bench this friday so I will let you know how it bolted up with that as well.
