It is currently Sun Feb 25, 2018 7:27 am
Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
 Vacuum motor check valves
I have my depression fitting in the top of my plenum box.
It matters where you pull it from?
Tue Dec 05, 2017 8:30 pm
Then i would say most likely you are running up against the limitation of the design.
Tue Dec 05, 2017 8:34 pm
jcisalive wrote:
I would not be able to use two 3" pipes because the air flow sensor is in the 3" pipe
What kind of flow sensor?
Is that blocking flow?
Tue Dec 05, 2017 9:25 pm
Thanks for the replies
It is like a mass air sensor.
It goes through center of the pipe and has a diameter of a pencil if I recall correctly.
I have two pieces of honycolmb air straightener before and two after the sensor. Maybe I will try flowing with one and see if it makes a difference. If it does I will take the other two out to see how that works.
Thu Dec 07, 2017 2:27 pm
as Bruce leading to, if you test the pressure at the motor box and compare it to your test pressure i am sure you will see the 3" tube at high flow starts to become a restriction.
Fri Dec 08, 2017 11:08 am
Thank you for the replies. I am very busy these days but I will test a few things in the next week or so and report back what I come up with.
Sat Dec 09, 2017 5:41 pm
I increased the size of the vacuum exhaust to 4" thinking that maybe the 3" could have been a restriction and did not make a difference.
I took both pieces of honeycomb air straighteners, before and after the air measuring pipe out and I was able to pull 28" on 450, up 45 CFM.
It seems the 3" from my plenum to vacuum box is the restriction as was suggested and the air straighteners do not help.
I will upgrade to 4" in the near future and report back.
Wed Dec 20, 2017 12:31 pm
Great news, pain in the butt but progress.
Wed Dec 20, 2017 1:39 pm
I did a test to see if the 4" would help before investing in an upgrade.
I set a calibration plate on my head deck and adjusted it until I had max cfm and 28" with all 8 motors running. It came in around 435 CFM @ 28"
Then I took out the 3" from the plenum to the vacuum box out and replaced it with 4" striaght PVC pipe and turned on all 8 again to see if the depression changed.
Without the measuring pipe I can only see depression.
Depression went from 28" to 34" with the 4" pipe. I ordered a 4" measuring pipe.
I will post then CFM and depression with the 4" when it comes in.
Fri Dec 22, 2017 7:16 am
Sounds like you are moving forward with your progress . . .
Fri Dec 22, 2017 9:58 am
