It is currently Wed Feb 21, 2018 7:05 pm
Reply to topic  [ 33 posts ]  Go to page Previous  1, 2, 3, 4
 Computer Flow BenchControl and Data Logging
Hi Guys,
Sticking with the data logging theme - I have been looking at picolog:
http://www.picotech.com/multi-channel-daq.html
as the basis of an engine dyno data acquisition setup.
Now, I know next to nothing about data logging so right at the bottom of the learning curve.
I have also heard Aduino mentioned several times - any thoughts on either of these routes for either flow bench or dyno?
I started a seperate thread in General Dyno Discussion about data for that application.
Cheers.
Tue Feb 07, 2012 5:32 am
That picolog would certainly work as a flow bench data acquisition system, but for a dyno you really need at least one high speed digital input for measuring speed/rpm.
Tue Feb 07, 2012 4:31 pm
Why not use a Bosch MAF? they come in all sizes, are available with analog (0-5v) or digital (frequency) output.
http://rb-aa.bosch.com/boaasocs/index.j ... cat_id=132
If you want to overcome the DAC 10 bit resolution you can use the digital in, providing youhave enough sample rate, IIRC they go till about 6-8kHz or so.. and good thing is if you use a standard one, you find voltage to flow curve directly online.. if you use one from a car, it's not too hard most of the times to extract the curve from the cars ecu (software), this is usually a curve with 16 or 32 breakpoints
Mon Feb 27, 2012 4:26 pm
