It is currently Sun Feb 25, 2018 11:40 am
Reply to topic  [ 3 posts ]
 Locating a leak
What is the best way to test your bench for a leak.I heard a pop noise when i was flowing an exhaust port and cannot seems to get the pressure i was getting before.I do not see anything that stands out.
Thanks in advance
Tue May 08, 2012 7:55 am
put it in exhaust mode with a few inches (10 or so should do) of positive pressure and spray some soapy water on all the seams, seals and fittings. i had some elusive leaks and tried using the velocity probe but the old soapy water trick is what finally did it.
Wed May 09, 2012 3:01 am
Yup, a bucket full of soap suds, and scoop up big hand fulls of bubbles will locate even a pin hole leak.
Wed May 09, 2012 6:01 pm
