It is currently Sun Feb 25, 2018 11:09 am
Reply to topic  [ 3 posts ]
 Sf110 int-ex flow difference
Hi all im a newbie woodduck lookin to pick the collective brains for an answer. I have a 110 yea sorry.....ok i have upgraded the motors and it has a pt black box with temp sensors.so when i flow the test plate ie 5/16 & 1 7/8 hole on int mode with correction factor i got 152.9 cfm @10" flip the test plate over flow in ex mode 165.4 cfm @ 10". Is this an inherent problem with this style of bench? I feel that it is a bit of a difference but am i just being too pedantic? Any input would be appreciated.
Thanks scotty.
Fri Feb 24, 2017 4:31 am
Sorry ....forgot to mention leakage on tests was under 1 cfm on both sides so not a bench leakage problem.
Fri Feb 24, 2017 4:58 am
Welcome to the Forum!
Seeing a difference in CFM between intake/exhaust is typical due to how the measuring orifice is "seeing" the airflow. The path the air is taking is not the same in intake/exhaust. That style flowbench is heating the air either after or before your test piece so temp has to be accounted for in the math to derive CFM
Fri Feb 24, 2017 7:24 am
