MSD style Flowbench Modifications
Bakerlite
Re: MSD style Flowbench Modifications
Post by Bakerlite »
Hijack away, I think most of the problem solving has been covered for this bench.
engineczar
Post by engineczar »
HI guys new to the party but I'd like some opinions on the method I used to modify my MSD style bench. Originally the bore sat directly over the orifice wheel like all the others that built off the PHR article. Rather than build a larger housing and install a baffle I opted to shift the bore over so it's no longer in line with the wheel. I attached a couple of pictures of the new location.
Flowing the calibrated plate I have sounds a lot better. Before I would get a loud whistle. Thoughts? Ok fix or am I just fooling myself?
Welcome to the forum,
The information is just opion as there is no real data to talk to, i suggest getting a couple of Bruces plates 100, 200, 300, then we can compare your calibration and linearity to other benches.
JMO
larrycavan
Post by larrycavan »
I would say that setup should help with the known problems of that design. You still need to calibrate. Get some plates.
