When calculating a rectangular port with radius corners, how do you subtract the area of the radius?
Example: intake port opening 2.57"h x 1.91"w with 5/8" corner radius
Formula for calculating throat cross sectional area?
Ray
Calculating Cross Sectional Area
Re: Calculating Cross Sectional Area
area of 5/8 dia = 3.142 x .3125 x .3125 = 0.3095 sq inch
area of 5/8 square = .625 x .625 = 0.5840
0.5840 minus 0.3095 = 0.2745 sq inch
subtract that from the large port area 2.57 x 1.91 = 4.9087
4.9087 - 0.2745 = 4.6342 square inches
hope you understood all this ..lol
Cheers
Lynds
Cheers
Lynds
Lynds,
First of all nice hearing from you again! I appreciate your formula and it helped a bunch. I did it, but my math came out a little different.
area of a 5/8" circle that I did was Pi X R^ or 3.1416X(.3125X.3125)= .306796875
area of a 5/8" square is .625X.625 = .390625
so the difference I get is .083828125 and subtracted from 4.9087 gives me 4.824871875 square inches. Am I missing something or doing it wrong? Or did I get the correct answer?
Thanks Lynds and John.
I was confused with the formulas for Area of a circle and circumference of a circle.
Ray
Ray
this is some good math, and i have added it to my notes.
One question though, how do you decide what size the corner radius is?
Is it as simple as measuring from were the bend starts to were it ends????
You can use radius gages or make some using a hole template available from most office supply stores or drafting supplies.Flash wrote:One question though, how do you decide what size the corner radius is?
Ray
I also find using the unsharpened end of a drill bill useful sometimes.Flash wrote: One question though, how do you decide what size the corner radius is?
http://www.facebook.com/SWAirFlowServices You know you want to "Like" it!
Sooo lets say i take a 1/4" drill bit and it fit perfection in the corner.......is that a 1/4 radius or 1/8 radius or...........................
And then do i times that # by 4 aka 4 corners? Before i subtract from to total?
Devide 1/4" by 2 equals 1/8" or .250/2 = .125" radius
Or you could use this calculator Stan Weiss posted on Larry Meaux's forum to do the math:
http://users.erols.com/srweiss/index.html#jcalc
Ray
Ray
Input Arc Radius o
Input Arc Diameter o
Yaah i seen that but was confused about my options
so if a 1/4" fit in each corner, i would enter .125 in each corner and then select Radius, not diameter...Right?
