Page 2 of 3
Re: MDF vs MDO. Is there a best choice?
Posted: Thu Aug 01, 2013 1:39 pm
You do know that MDF with the color Green adhesive is water proof. And can bought at Lowe's or other lumber yards .
The inner laminates are claimed to be void free
Key word here is ( Claimed ) I have worked with MDO for about 3 years & found voids in MDO & You must be careful what paint you use or you will see separations of those ply s
Posted: Thu Aug 01, 2013 1:45 pm
Thanks Malvin. That is very good to know. I have never used it and so the way mdo was presented it sounded like the answer to all of our prayers.
I don't know how true it is, but I have heard a lot of the wood at HD and Lowes is coming in from China. Anybody know?
Posted: Thu Aug 01, 2013 1:58 pm
Yep its from across the pond .
Here is a link to water proof MDF
http://www.mdf-plywood.com/pid13455045/ ... f+wood.htm
Here is where I go when I need very good Quality MDF Or HDF its about twenty minutes from my
house .
Here is the link to that place
http://www.industrialplywood.com/13info_core.html
Posted: Thu Aug 01, 2013 3:18 pm
That water proof mdf can be purchased up to 25mm thick. That is .984" almost a inch thick. That would one heavy floe bench.
Posted: Thu Aug 01, 2013 6:53 pm
Yes indeed !
I used one inch MDF bolted to a steel angle frame, my bench weighs about 350 Kg (770 Lbs)
No problem its on wheels, but has never moved an inch from where I first built it about ten years ago.
Posted: Thu Aug 01, 2013 8:48 pm
Tony wrote:Yes indeed !
Holy crap batman, I thought it would be heavy but not heavier than a top fuel hemi
Posted: Thu Aug 01, 2013 8:55 pm
Haha, a 10Hp three phase motor is not exactly light, and neither is the cast iron housing for the centrifugal blower. Its not as if I am continually moving the thing around.
Posted: Thu Aug 01, 2013 9:02 pm
You don't have to worry about it blowing away either
Posted: Thu Aug 01, 2013 9:51 pm
That reminds me of a blower I once made for radiator cooling on a dyno.
It has a 3Hp motor fitted to a 15 inch barrel centrifugal, it delivers around 8,000 CFM coming out at around 40 Mph.
Its mounted on two wheels.....
The first time I powered it up it chased me around the double garage like a dog on a chain anchored by its rather long power cord.
A fairly memorable experience.
Posted: Fri Aug 02, 2013 12:12 pm
by slracer
Tony, I'd like to see a video of that!
-- Doug
