Newbie saying Hi.
Re: Newbie saying Hi.
I suggest you try running it first and see if the noise level is acceptable.
bob
Post by bob »
Tony wrote:I suggest you try running it first and see if the noise level is acceptable.
They have a silencer built into the vac inlet but I will try them, I need to work out how best to house and pipe them into a flowbench. Got all these ideas rattling about in my head,curious to know if these pumps have found there way into other flowbench builds and how they got on.
Bob
Not all the noise is in the airflow.
The pump casing itself will scream pretty loudly.
bob
Post by bob »
Tony wrote:Not all the noise is in the airflow.
I am in the workshop over the weekend, I will wire one of them up and try it.
Bob
bob
Post by bob »
I have wired one of them, its actually quieter than the shop vac. Tried to measure flow with a hand held electronic gadget I bought off ebay and it cant read the cfm if I hold it against the ports, it goes off the scale holding it about six inches from the inlet port.
Bob
That's really good Bob, I have hard some pretty loud ones.
bob
Post by bob »
I picked up a few of these 6" motorised valves that work with 6" solvent weld pipe, not sure how they will cope switching between vacuum and pressure or whether pumps will need to be turned off first. Struggling a bit to find a solution to getting the two pump outlets/inlets coupled and connected to the bigger pipe in a way that still gives me access to the pumps filters.
bob
Post by bob »
I have a plan of the proposed pipework for the flowbench.
Port 6 on the bench would be the port to the cylinder head and vent port 7 is either vac or blow depending on whether the bench is sucking or blowing, thought it a better idea this on the bench rather than having the draught from the vac/blowers howling about my legs when in use.
I was thinking of using the electric shut of valves as follows.
Valve 1 and 3 open with 2 and 4 shut to provide vac at port 6
Valve 2 and 4 open with 1 and three shut to provide blow at port 6
[URL=https://app.photobucket.com/u/mypi ... unds[/img][/url]
bob
Post by bob »
Can anyone see a problem with piping this up this way or any reason it wont work ?
Bob
bob
Post by bob »
I managed to find a new old stock VFD big enough to control both of the motors, I will wire them both up temporarily to make sure it works. I think that's most of the bigger purchases taken care of, time to start a build.
https://hosting.photobucket.com/images/ ... ys/vfd.JPG
