Flash,
I found this on the net take a look, and do a little more research.
The Bigger Your U-Tube water,.....The More Inaccurite?????
Re: The Bigger Your U-Tube water,.....The More Inaccurite???
Rick, thanks for that article,education is grate!!!!
Had no clue that there was a dot 5 and a dot 5.1
I was told that silicone brake fluid was moisture attraction, when it is vary much the opposite..........they mix like water and oil.....They DON'T!
Thanks for the education, a little
but am the better for it!
I have acquired a 48" pdf file for MM oil and gave the print shop the go ahead just hours a go
I have changed my mind on the dot 5 brake fluid. At this point, I feel it is a better choice.
some one in the "now how" should make a pdf file for DOT 5 fluid!!!
Then there could be some true testing of it.
Flash,
You have to do what is best for you BTW it realy does not matter as the math solves all the problems.
Just dont talk to me about % Scales LOL
