here you go
RacePumper
Alternately 8 of these motors possibly 300-340cfm @ 28". ( When motors are grouped they "steal" a little air from each other, that's why the total flow estimates are lowered )
I agree also Malvin, I think although the Panasonics are cheap, they are too small for what we need in a bench build. The low cost of motors would be long forgotten when you can't flow what you wanted because of poor choices. I made my suggestion but they are out of his budget it would seem.Malvin wrote:
I have to agree 100% with Storm that he is rushing and would regret making a choice with vacuum
motors that are not with in a average sealed Vac of 96" to 110" and flow max of no less then 135 CFM to 147 CFM
from what have seen looking at vacuum specs .
Have you ever run those 6 motors by themselves and noted the peak flow? I know that every bench is different but I think its important in design if we can get an approximate factor in how much is lost in total flow when motors are grouped. I currently just go on personal experience from my few bench builds and what I read here and other guys I have helped out outside the forumMalvin wrote:
Jim I doubt very much with those vacuum motors he would ever see 340 CFM @ 28" depression
I forgot to add I have 6 of those vacuum motors![]()
RacePumper
Sounds like a lot of work, I don't think I would bother doing it, adding one motor or using the right motors would be a better option in my opinion.damunk wrote:Is this because we should design the pipe work from each motor similar to a car exhaust manifold then link them all to one main pipe like an exhaust so there is no back pressure problem....
Where there is only one motor, the air moves towards the motor intake hole from all directions, and accelerates as its gets closer to the motor intake. Its a pretty orderly process.damunk wrote: Also when you talk about more motors combined "stealing" from performance from one another.
