Oh and please do not harp on the motor thing as there are many benches on this form with dumpster motors, if you are to proud to dive I will sell you some new ones real cheep. I think you could flow close to 175 cfm at 28” and 250CFM at 10” using a 6” Delta P with 2 average motors.
For what it is worth Bruce and I have been passing plan ideas back and forth about what we call the cube it will be a bench top two motor reversible flow bench designed to run on a 6” DP PTS DM for the Karter’s and small port heads.
Yup 2 dumpster motors and to quality store ones.
I should have went with a 6" dp instead of the 12" and i could have flowed my heads at 28" instead of having to figure up from .300 lift, and i still could!.........
But i think, i will, build a full side PTS 6-8 motor bench before i do that.
If i would have use the material that i had on hand(two free large desk/tables made of mdf/laminated) and make a larger settling chamber/ upper chamber,............. a accurite flow bench would have come much easier.
I think the "cube" idea, is a grate one!
