damunk wrote
I've decided to spend the extra money on better motors.
I think two/three good motors might be enough for me now.
If your budget will let you get 3 of the better vacuum motors would be the way to go
I think the same. But...............Malvin wrote: If your budget will let you get 3 of the better vacuum motors would be the way to go
You need to work out what style of bench and manometers you are going with. If you put an orifice or a flow element in the pipe, It is known as a PITOT flowbench. You can get numbers but the accuracy ( in this design ) is questionable and compensations are required. The other type of flowbench we talk about here is an ORIFICE bench, where the measuring orifice is inside a larger pair of chambers. The orifice bench is the better type in my opinion, but others will disagree.damunk wrote:
Jim,
sorry I don't understand.
I want to make the pipe from the motors up to the test piece with a way to test the flow, velocity .
Just want it simple as poss and accurate for the money I spend.
I'm porting and polishing a 1.4 head for personal use but at the same time learning about the flowbench builds. I read on some forum posts that 1.4 heads flow from 140-160cfm whether that's right.
And reading more about pressure drops. I've decided to spend the extra money on better motors.
RACEPUMPER wrote: You need to work out what style of bench and manometers you are going with. If you put an orifice or a flow element in the pipe, It is known as a PITOT flowbench.
Good move Damunk, You won't look back with quality motors. You can use the waiting time to build your bench up to the point of motors and read, read, read.damunk wrote:Ended up buying 119996-00 ametek. But will have to wait a month to get them as they are on order.
Yes out past the coil windings. Helps coolingdamunk wrote:
I can see where they suck in air, It's obvious as theres a fan there. But on the back size all I see is electrical coil wires. Where does it blow out from? There is nothing spinning on the other side or and only minute gaps for the air to come out of.
The ones I have are similar looking to the photo. Just 9 times more expensive, and 1400 watts, 2 stage, forced motor cooling.. 4 of mine pull just over 300cfm at 28"... Think I'll go for something cheaper next time, if I am upgrading to 12 motors sometime.damunk wrote:I am going for the below:
Main reasons why:
1) It says it is genuine ametek. Something tells me it's not but have to trust what it says on the listing.
2) Low wattage: 1000w - If 4 motors then 4000w max which I can cope with (I am using it on a 1.4 litre head so I am assuming 150-200CFM is max required. Surely even with 4 bad motors it's sufficient flow.
4) 230v - UK use.
5) It's cheap as chips: £28.75 including postage) to UK.
5) Wet & Dry - Not sure what that means but with carburetor tuning - would this help?
6) It's double stage - Read on forums that doube stage CAN better than single stage.
I will buy just one and see what it is capable of. Or is it just worth going for the whole hog of 4. The project might take 6-8 months and worried about not having the same 4 motors later down the line.
