Here is what I'm tying to do.
I want my water pump to turn on (electric water pump) at 150-160* and my cooling fan to turn on around 180*F
The reason i want my water pump to turn on at this temp is that my new motor is not going to us a T-stat so the electric water pump will be a little bit more effective at moving water around.
I can buy a dual fan kit that would accomplish this for 150-200 dollars, but I'm cheap
I found a sensor that screws onto the block/manifold(coolant passage) from V.D.O. Part number 232-011-017-093D for a 167*f and 232-011-017078D 176*F.
Only problem is that i cant by just one!!!!! i have to buy a 150 of each number
what i would really like to find is a sensor that bolt to the intake "bolt" that turns on at 160 and a radiator probe type that activates around 180*F
