This is what the temp was before I went to bed last night
when I got up this morning it was 10º below 0 with out wind chill
did not get a picture of that.
Pictures of where you live or work
Re: Pictures of where you live or work
You should go outside and piss when is like that and see if it freezes before it hits the ground
I will let some one else do that John
I can say that if you boil water then toss it in that
cold air at that temp you will get tiny little ice balls plus it makes
a loud cracking noise
This should be very dangerous! Can break the garden hose.jfholm wrote:You should go outside and piss when is like that and see if it freezes before it hits the ground
And he may also get frozen "stiff"Hotz wrote:This should be very dangerous! Can break the garden hose.jfholm wrote:You should go outside and piss when is like that and see if it freezes before it hits the ground
stiff I do not know! But extremely small for sure ..jfholm wrote:And he may also get frozen "stiff"Hotz wrote:This should be very dangerous! Can break the garden hose.jfholm wrote:You should go outside and piss when is like that and see if it freezes before it hits the ground
It doesn't.You should go outside and piss when is like that and see if it freezes before it hits the ground
I live in MN. When I'm cutting wood outside or ice fishing that's not near cold enough to freeze that way.
Not to be overly technical or crude, but at -15*f a strong stream will not fully freeze, but droplets will.
It depends on wind speed.
I have done that as a kid, maybe -25*f? It crackles before hitting hard ground.
The temps that would freeze it from waist height are cold enough I wouldn't try.
A pan of boiling water will certainly freeze if thrown up into the air.
It's going to be -17* tonight, If I can convince my wife to give mouth resuscitation, I might attempt it...In the interest of scientific experimentation, of course.
No, I will not stand on the roof.
No, I will not send a video.
Now thats the closest thing we have had to PORN on this forum since Johns Pink Port Molds!
Hey did any of you guys in Pennsylvania get up early enough to see this?
http://www.ksl.com/index.php?sid=335338 ... id=queue-8
