Page 4 of 8
Re: dyson motors
Posted: Sun Oct 11, 2015 8:48 am
by damunk
storm wrote:Is there a part number?
I think you are rushing into this, based on what you have written, and I think you will regret it later.
MPN: 08-SPG-227 EAN: 5056026827553
Re: dyson motors
Posted: Sun Oct 11, 2015 9:43 am
Are you sure that's right? That number's not of the Ametek website and the number isn't consistent with Ametek's normal part numbering scheme, a typical Ametek number is of the form 11xxxx-xx or 12xxxx-xx
Re: dyson motors
Posted: Sun Oct 11, 2015 9:54 am
by damunk
Yes. The seller sells quite a few "what are listed as Ametek"
Page of this thread and the links to the auctions are there.
http://www.ebay.co.uk/itm/Double-2-Stag ... 487dd2cbbb
Re: dyson motors
Posted: Sun Oct 11, 2015 10:37 am
by Hotz
The numbering supplied for second-line engines, vacuum cleaner manufacturers such as Electrolux in no way is found in Ametek tables. I do not know why but I stayed hours looking for that information. I believe that these engines are not made in America, but in China.
And they are manufactured under license of Ametek but are forbidden to provide detailed technical information. Especially in most of the world is not used as a parameter CFM suction capacity but is used Watts.
Re: dyson motors
Posted: Sun Oct 11, 2015 5:20 pm
damunk wrote: 6) It's double stage - Read on forums that doube stage CAN better than single stage.
Single stage motors are generally more efficient at lower back pressures.
Two stage motors generally more efficient at higher back pressures.
Where we are working at around 44 inches, puts us in about the middle of the pressure range, where either type could be better or worse than the other.
You need to eyeball the pressure flow curve to determine the efficiency at 44 inches to judge.
CFM per amp at 44 inches is the bottom line.
For 220-240 volt motors 8 to 16 CFM per amp covers the range you are likely to see.
For 110-120 volt motors 4 to 8 CFM per amp because with only half the voltage, the motors can only develop half the drive power for the same current.
Re: dyson motors
Posted: Sun Oct 11, 2015 6:15 pm
Check these guys out, they won't sell to you directly, but they give contact details of retailers in your area
[urlhttp://www.europart.co.uk/42-VM-603][/url]
That link is the 119996 ametek that I like.
Re: dyson motors
Posted: Sun Oct 11, 2015 6:17 pm
Re: dyson motors
Posted: Mon Oct 12, 2015 4:19 am
by damunk
I rang them and their distributor near my area is too expensive. £68.00 each
If only the ebay ones listed the part no's.
Numatic one here: http://www.ebay.co.uk/itm/Numatic-Henry ... 5b13028c0f
Re: dyson motors
Posted: Tue Oct 13, 2015 12:57 pm
by damunk
http://www.ebay.co.uk/itm/171633835211? ... b1ac3&cp=1
Confirmed as genuine Ametek : Part no: 061300501
General Performance:
Max air watts: 220
Sealed Vacuum: 76 inches
Max airflow: 87.7 CFM
Motor Performance Operating at 3/4 ! - 19mm Orfice
Vacuum: 39.7 inches
Airflow: 47 CFM
Input Watts 735
Input Amps: 3.4
Air watts: 220
18250 RPM.
Now the question is: Is the the one on the below link the exact same one as the above:
It looks very similar in appearance.
Re: dyson motors
Posted: Tue Oct 13, 2015 1:35 pm
Difficult to say for sure.
But you could always buy just one and then test it yourself.
