Flow bench head stand how can i make one?
Posted: Thu Oct 08, 2015 9:01 pm
by drifter
I just picked sf100 bench looks the same as a sf110 im not sure what the difference is.It did not come with the plexiglass table stand dose anyone have any pics of how they made up something to mount heads on mostly sb chevy for now
Re: Flow bench head stand how can i make one?
Posted: Fri Oct 09, 2015 11:49 am
by Hotz
Welcome.
I did not understand exactly what you need.
But I believe that's it.
http://ultimateaircooled.com/tools/1149 ... stion.html
Posted: Fri Oct 09, 2015 1:20 pm
by drifter
Yes thats what i need does anyone have a cheap way that i can build my own? Or are there any forsale anywhere?
Posted: Fri Oct 09, 2015 10:09 pm
by Hotz
You can make MDF or similar. and using a tube with a diameter that you need ... The demension take based on the cylinder head and the base of the SF.
I believe it is very simple ... good luck.
Posted: Sat Oct 10, 2015 9:59 am
Basically your head stand or adapter needs to be the same size as your bore to shroud ( or restrict ) your valves the correct amount. The general idea is to have the height dimension equal to your stroke or longer. The bore diameter is crucial to your testing, where as your height doesn't alter the readings too much
Posted: Sat Oct 10, 2015 11:15 am
by Hotz
In this video of a DIY PTS FB you can see better.
As Jim said you must have the hole diameter equal or approximate diameter of the cylinder of your engine
I particularly want to build my media with the Course and diameter identical to the engine design for testing the cylinder head.
A drawing I did.
by mop5ter.
