16 CFM WITH NO MOTORS TURNED ON
I built a flow bench with pts plans this past winter ben very happy with it used it a lot at first, then other things took up my time so I did not use it for a couple months , now when I try to use it my computer soft ware says I have 16 cfm of air flow with no motors turned on. if I power down the dmm it will say zero briefly then climb back to 16 cfm ,air flow test pressure says 0 any thoughts.
Re: 16 CFM WITH NO MOTORS TURNED ON
If you're using the pts dm this is very normal. Check in the dm area of the forum for the reasons. If you aren't using a pts, we need a bit more information.
Power the DM up and let it set for a couple hours if it does not settle down contact Bruce through a PM and he can help you calibrate.
