I have had a SF110 for many years and it has served me well doing small engine heads and carbs.
A few years ago I was gifted a Blue Box that Larry Cavanaugh produced. (RIP)
It also has served me well.
The Blue Box has ports for velocity probes and I have used them with PTS probes.
Is it possible to tap into the head adapter or the SF110 to read the velocity directly?
Jeff
SF110 Velocity
Re: SF110 Velocity
Can you elaborate on what you are trying to do, not sure what tapping the head adapter would give you?Is it possible to tap into the head adapter or the SF110 to read the velocity directly?
Are you thinking or measuring tte velocity on the piston/cylinder side of the flow?
