Newbie saying Hi.
Re: Newbie saying Hi.
O/k fine Bob, should be possible to make a big muffler for the return air.
bob
Post by bob »
Tony wrote:O/k fine Bob, should be possible to make a big muffler for the return air.
Tony I have been looking at all sorts of different fans but keep coming back to that monster,the only thing that concerns me with it is getting hold of a speed controller for it or finding out it cant be used with one.
Bob
If it has a thee phase motor, a variable frequency drive is the perfect solution.
the three blue wires in the picture are highly suggestive.
If its a single phase motor, forget about any speed control, its just not possible.
bob
Post by bob »
Tony wrote:If it has a thee phase motor, a variable frequency drive is the perfect solution.
Its definitely three phase Tony. I think I am on the brink of doing a deal on this unit, it works out less than a quarter of the cost off buying hoover vac motors. Just need to be sure its the right thing for the job.
From the ad
“COLLECT IN PERSON OR I CAN POST THIS TO YOU AT EXTRA COST ? ? 3 PHASE - BECKER VACUUM PUMP / VENTILATION FAN - ( TYPE G160 A ) - 400 VOLTS - 0.2 AMPS - SPEED 1350 RPM - POWER 80 WATTS - AIR PRESSURE 50 Pa - CAPACITY 1300 M3 / H - MADE 2010 - MADE BY DIETZ - 4 INCH / 100 mm INLET + OUTLET -. THE PUMP IS MADE BY BECKER IN 2011 - TYPE SV 5-690 / 1 - 01 - SPEED 2900 TO 3300 POWER REQUIRED 11 TO 13.2 Kw INLET CAPACITY 690 / 900 - M3 / H -PRESSURE 410 / 395 M BAR - VACUUM 285 / 320 M BAR - IN VERY GOOD ORDER - READ THE BOTTOM DESCRIPTION FOR FULL DETAILS ?”
Tag
https://app.photobucket.com/u/mypickys/ ... cf865e9438
Bob, is that right ?
That is tiny, less than one vacuum cleaner motor.
I hope you are bidding on both pumps and not just the first one.
You will also need a 15Hp to 20Hp variable frequency drive to run it, which will not be cheap even secondhand.
bob
Post by bob »
Sorry Tony, that last picture was of the plate off the separate cooling fan which cools the main motor.
This is the plate off the big motor.
https://app.photobucket.com/u/mypickys/ ... 2f854825f9
bob
Post by bob »
Cost of wiring in and the speed controller is more than the vac unit, as its outside I was wondering if it wouldn't be easier/cheaper to junk the electric motor and direct drive the vac pump with a small kubota diesel engine, use the throttle to regulate speed/airflow.
Bob
I really have no idea Bob.
bob
Post by bob »
After taking onboard Tony`s comments and doing a bit more research it would seem a bit easier to go for a couple of smaller 5.5kw side channel blowers, speed controllers for these seem far more reasonable at about £120 each and it would appear there is space for two inside under the bench These units make about 250cfm and 300kpa each. The vacuum side of things seems a bit excessive at 1200 inches, not sure if this matters
One turned up the other day
bob
Post by bob »
Second motor has turned up, now need to give the plumbing some consideration.
