Hi guys a newbie here from across the pond. I am thinking of building a flowbench and was steered onto this site via another forum.Not keen on having another gadget rolling about cluttering the workshop,I was hoping to mount the motors with all the noisy bits on an outside wall and pipe to an existing bench. Not sure of the implications of running the extra few meters of ductwork or whether to go with vac motors or get a single unit.
Meanwhile I will have a nose about on here an scavenge for some inspiration.
Its been done before, a separate motor box connected by a duct to the settling chamber by a duct.
To change from suck to blow, just turn the motor box around.
Its going to require two units which will overall, be much larger than building it all into one very neat enclosure.
Be very careful with an inside/outside construction. The air needs to freely recirculate. The pressure generated can easily destroy a building.
Think about it, 28 inches is about 1Psi that is 144 Lbs per square foot. Literally many TONS of force could be generated that can easily burst your ceiling or a wall. If you duct the air directly back into your shop, there will be no noise advantage in placing the motors outside.
Tony wrote:Welcome to the Forum Bob.
Thanks for the heads up on recirculating Tony, its not something I had thought about. The trouble is my shop is an old war department nissen hut and is fitted out with cupboards, the only space left for a flow bench is the bit I build engines in so I was hoping to get away with adding the flowbench stuff into the worktop.
This is the only place I could site the flowbench which would mean having the motors outside.
That looks like a ring blower.
They are incredibly noisy.
That cylindrical "sausage thing" at the bottom is a muffler.
But it will still going to wail like a set of bagpipes from Hell.
600CFM at 128 inches of water is pretty impressive though.
The figures look good, but the potential noise level of something that large is a bit of a worry.
Tony they call them side channel blowers over here, the noise isn't a problem because its going outside and I live on a farm a long way from other properties. I have only put in an offer at this stage, if that one doesn't happen I can get two smaller units. There are some smaller used units available with speed controllers already fitted, they may be a better option.
