3D printed valve opener test
tafeteacher
Post by tafeteacher »
This is a test picture for the 3D printed valve opener
tafeteacher
Re: 3D printed valve opener test
Another view
tafeteacher
And a couple of the fixture to hold the linear sensor for the camshaft lift measurements in Audie Tech CAM Pro. These new resin printers are sooo nice
Those are some nice prints!
tafeteacher
Brucepts wrote:Those are some nice prints!
The resin printer is awesome. It's a bit unusual how you're supposed to print at 45 degrees, however it does turn out very nice. There is some shrinkage issues, however I'm working my way through that so I can factor shrinkage in when designing the part in the first place.
tafeteacher
Some pics of making the parts
tafeteacher
When printed it comes out a bit like perspex, and you can drill it. It does seem to harden a bit more over time and become a bit more brittle, however I'm still learning with it.
The one upside is it means I can design a valve opener that is designed for 3D printing and I can make it at home without going into the workshop to use the manual or CNC machines. Draw it, print it, flow it.... That's the plan anyway
Does the slicer generate the supports?
I watched a few videos of the process, look like it can be a messy/smelly process?
tafeteacher
It can be I guess. I've been extra careful and have been using a product called E-Sun PLA Pro. It's meant to be "ABS like". We started at work using the E-Sun PLA and did find it quite smelly to the point it was annoying, however I've found the PLA Pro to be hardly smelly at all. My wife hasn't complained about it, so it must be OK...LOL
The big difference is that the part is solid. You also have to think a bit about how you design it.
Yes it generates the supports automatically however you can change it and add supports or drag the support around. It's quite reasonable to use to be honest.
The trick is to tilt it at an angle for printing. We did the first couple of prints like we would for an FDM printer. They were hard to remove. I've found it doesn't like large flat surfaces and is better on detail. The valve opener and Cam Pro Plus holder were pretty good to do. It's definitely how I'll do cylinder head specific valve openers going forward.
I've done a 6 tube bulkhead fitting to bring all the pressure points into a box that will hold all the electronics. It turned out pretty good. I'd be happy to mail you a couple if you like and put the STL file up if anyone wants to print one.
Does open up new possibilities on projects!
Been using my 3d printer for all sorts of things in the shop, mostly layout fixtures and rapid prototype before making the part in aluminum/steel.
I'm behind the curve on 3d drawing/design though so each project has been a learning experience.
