tangential bypass Vacuum motors?
Posted: Thu Jul 06, 2023 11:26 pm
by Bearwen
So I have seen a lot of tangential bypass vacuum motors that have good flow numbers and good current draw numbers.
Sometimes the price is good for the lower you get as well.
So can you use this type of motor on the PTS flow bench build?
Obviously you will probably have to make your own mount plates and I'm guessing you will need to clock the tangential bypass port so that the air coming out isnt obstructed to the best ability anyways.
Just wanted to ask as I am in the finding the right parts to order stage and did t want to pass up any motors if they work and I can get good cfm and reasonable current draw and price of course.
Thanks for the help so far and all the knowledge that you guys share.
