Hi All,
I am working on a new project, blowing this time instead of sucking. I notice the air coming out of the flowbench is much hotter than the air going in (not real surprising). Which air temp should I be using for my calcs, ingoing air temp or outgoing air temp? This is a pitot style bench with liquid manometers.
Bill
Air temperature
Re: Air temperature
Bill
You need to measure the tempriture of the Air going through the Pito Tube.
Re: Air temperature
Which would be very close to ambient in this case, since it is sucking past the pitot.
Thanks again.
Bill
Thanks again.
Bill
Re: Air temperature
Oh ??b.shaw wrote:Which would be very close to ambient in this case, since it is sucking past the pitot.
Thanks again.
Bill
I thought you said this was to be a blow type bench.
