Page 1 of 3
Calculating Cross Sectional Area
Posted: Wed Dec 01, 2010 1:47 am
by coulterracn
When calculating a rectangular port with radius corners, how do you subtract the area of the radius?
Example: intake port opening 2.57"h x 1.91"w with 5/8" corner radius
Formula for calculating throat cross sectional area?
Ray
Re: Calculating Cross Sectional Area
Posted: Wed Dec 01, 2010 2:09 am
by tweaks
area of 5/8 dia = 3.142 x .3125 x .3125 = 0.3095 sq inch
area of 5/8 square = .625 x .625 = 0.5840
0.5840 minus 0.3095 = 0.2745 sq inch
subtract that from the large port area 2.57 x 1.91 = 4.9087
4.9087 - 0.2745 = 4.6342 square inches
hope you understood all this ..lol
Cheers
Lynds
Posted: Wed Dec 01, 2010 3:03 am
Lynds,
First of all nice hearing from you again! I appreciate your formula and it helped a bunch. I did it, but my math came out a little different.
area of a 5/8" circle that I did was Pi X R^ or 3.1416X(.3125X.3125)= .306796875
area of a 5/8" square is .625X.625 = .390625
so the difference I get is .083828125 and subtracted from 4.9087 gives me 4.824871875 square inches. Am I missing something or doing it wrong? Or did I get the correct answer?
Posted: Wed Dec 01, 2010 4:57 am
by coulterracn
Thanks Lynds and John.
I was confused with the formulas for Area of a circle and circumference of a circle.
Ray
Posted: Wed Dec 01, 2010 2:16 pm
by Flash
this is some good math, and i have added it to my notes.
One question though, how do you decide what size the corner radius is?
Is it as simple as measuring from were the bend starts to were it ends????
Posted: Wed Dec 01, 2010 2:56 pm
by coulterracn
Flash wrote:One question though, how do you decide what size the corner radius is?
You can use radius gages or make some using a hole template available from most office supply stores or drafting supplies.
Ray
Posted: Wed Dec 01, 2010 6:27 pm
by SWAirflowServices
Flash wrote: One question though, how do you decide what size the corner radius is?
I also find using the unsharpened end of a drill bill useful sometimes.
Posted: Wed Dec 01, 2010 8:21 pm
by Flash
Sooo lets say i take a 1/4" drill bit and it fit perfection in the corner.......is that a 1/4 radius or 1/8 radius or...........................
And then do i times that # by 4 aka 4 corners? Before i subtract from to total?
Posted: Wed Dec 01, 2010 8:48 pm
by coulterracn
Devide 1/4" by 2 equals 1/8" or .250/2 = .125" radius
Or you could use this calculator Stan Weiss posted on Larry Meaux's forum to do the math:
http://users.erols.com/srweiss/index.html#jcalc
Ray
Posted: Wed Dec 01, 2010 9:06 pm
by Flash
Input Arc Radius o
Input Arc Diameter o
Yaah i seen that but was confused about my options
so if a 1/4" fit in each corner, i would enter .125 in each corner and then select Radius, not diameter...Right?
