Beryllium valve seat
Posted: Mon Apr 30, 2012 11:16 pm
by Hotz
Hello guys ...
some information interference assembly seat valves.
I have to head Alfa 164-V6 repair, seat Beryllium ...
In normal use seats of valves **steel** 0.10 / 0.12 mm (0.00394/0.00464 ยจ) Pressure to install
Anyone with information?
Re: Beryllium valve seat
Posted: Tue May 01, 2012 2:34 pm
by Hotz
Posted: Wed May 02, 2012 9:04 pm
by SWAirflowServices
$169 per valve for a motorcycle application? $676 a set? No wonder I haven't used these before.
Posted: Thu May 03, 2012 7:40 am
by Hotz
SWAirflowServices...
Hard work or not?
Posted: Thu May 03, 2012 7:22 pm
No, not bad at all. Likes a squirt of lube when you are machining the valve seat profile. Also, we end up doing some weird oscillations with the cutter speed. It's like the material likes a load on the cutter so we start with a slow speed and give it a "stab of the throttle" when it starts cutting.
Oh, and be careful because Beryllium is a very carcinogenic substance!
Shane
Posted: Thu May 03, 2012 9:25 pm
by Hotz
thanks shane ...
Valuable information ...
good luck...
Posted: Fri May 04, 2012 9:34 pm
Shane is right, beryllium is also used a lot in the electronics industry for it's hardness and very high thermal conductivity.
It is also EXTREMELY poisonous, especially any dust from cutting, fracture, or grinding.
Keep it right out of your lungs or any open wounds, it is very nasty stuff.
Posted: Fri May 04, 2012 11:31 pm
by Dan_DiM
i never cut it on valve seats but used to make bushings out if it. use sharp cutters because it work hardens easily.
Posted: Sat May 05, 2012 8:40 am
by Hotz
Posted: Sat May 05, 2012 9:30 am
Scary stuff indeed!
Those cases dealt with long term exposure, any idea what the risks associated with short term occasional exposure are?
