240 volt vacuum motors for wetflow bench
can someone help me locate a motor that would be suitable to use in a wetflow bench? thanks for any help, im not sure if i posted this in the correct section, im not real familiar with this forum
Re: 240 volt vacuum motors for wetflow bench
Not sure if you can get a vacuum motor that is electric that would be
suitable but you can build a attachment to your flow bench to do wet flow testing here is the link to that here at PTS forum
http://www.flowbenchtech.com/forum/view ... f=16&t=457
Hope this Helps you!
A-Vega,
Once you understand the operation of a wet flow bench you will understand that the water is not supposed to come in contact with the motor system.
Chris is our local wetflow guy. You have two methods of testing Blow through which requires the least effort in seperation or suck through where you will need more advances air-water seperators.
As a first step in learning look at how your shop Wet Vac works (Ass you me ing you have one)...
