Inch of water to fps
Place to add formulas. If you post a formula please make sure your abbreviations are spelled out so it avoids a lot of follow-up postings. I know a lot of abbreviations are common or taken to be common knowledge. Please be sure to checkout the new FAQ of common abbreviations.
Please post formulas in separate topics, do not add formulas to someone else's post unless it relates to the original post. Also in the topic line make a note of what your posted formula is about . Thanks
Flash
Post by Flash »
Formula - (inches of water^0.5)*66.2
Can some one give me the "long hand" version of this equation.
Inches of water(^)????
Do i add water to .5 or do i times... .5x.5 Can't seam to get the right answer.
86rocco
Re: Inch of water to fps
Post by 86rocco »
The carat ^ is the symbol used by most common spreadsheet programs for the exponent function so A^2 means A squared and inches of water^ 0.5 means inches of water to the exponent 0.5 which is just another way of saying the square root of the inches of water.
Flash
Post by Flash »
can you put it in an example so my pee brain can grasp it. :oops:
86rocco
Post by 86rocco »
Sure, let's say the pitot pressure is 16 "WC, the velocity in fps is 66.2 x 16^0.5 = 66.2 x √16 = 66.2 x 4 = 264.8 fps.
BTW, have you seen my spreadsheet, haven't you?
Flash
Post by Flash »
I lost that one when i switch computers THANK YOU.
And thanks for spelling it out for me. I get it now, and the ## work, Yeah!
thanks again for your time ;)
