Bore adaptors
Sean
Bore adaptors
Post by Sean »
Hey guys, does anyone have good plans to make a bore adaptor that can have the bore sizes changed? Or a link to just buy one.
Cheers
Sean
Re: Bore adaptors
They are pretty easy to make, and as far as I know most here seem to fabricate their own to suit a specific personal favorite engine.
coulterracn
Re: Bore adaptors
Post by coulterracn »
Stumper wrote:Hey guys, does anyone have good plans to make a bore adaptor that can have the bore sizes changed? Or a link to just buy one.
Cheers
Sean
http://www.castheads.com/aluminum_flow_ ... _stand.php
Sean
Re: Bore adaptors
Post by Sean »
Wow for those prices I will make my own lol, yeah I will just have to get buddy buddy with the local machinist I think, I have lots of different engine types to work on so I will have to make a number of adaptors, oh well add it to the list hahaha. Thanks guys
coulterracn
Re: Bore adaptors
I've made several using cast iron cylinder sleeves and cabinet grade plywood.
Re: Bore adaptors
You need something pretty decent to support the weight of the head, but the actual bore tube itself could be pvc pipe or thin wall stuff.
In Australia, standard PVC sewer pipe is 4 1/16" bore (103.2 mm)
Hotz
Re: Bore adaptors
Post by Hotz »
MDF with good thickness, router, PVC pipe, as Tony says glue slot PVC ... Easy. :)
Tony which the measurement system in Australia? metric or inch
Re: Bore adaptors
We are completely metric here now, we officially converted from imperial in 1970.
But some things like pipe and pipe threads still use the original exact inch sizes rounded to metric.
For instance, 3/4 inch bore water pipe is really 19mm bore, but we call it "20mm pipe"
Four inch sewer pipe is "100 mm pipe" but it's really a bit bigger than that.
We still use the same old British BSP imperial pipe threads on our new metric water pipe.
Only place in the entire world still officially stuck in imperial is USA.
Hotz
Re: Bore adaptors
Post by Hotz »
Tony wrote:We are metric here now, but we used to be imperial a very long time ago.
Only place in the entire world still using Imperial is USA.
Here in Brasil, little things still use imperial.
thanks.
Re: Bore adaptors
This map is pretty interesting. Image
