I had a Superflow 110 for 38 years and just sold it. Had to borrow another while waiting for the build up.
The guy cracked, then remover the graphic on the front that shows the flow ranges and orifices to use. Can anyone post a close up pic of that chart?
Or point me to a spot where I can pick it up....
sbm
SF100 Flow ranges
Re: Flow ranges
I found the Instructions for the super flow 110
http://www.freewebs.com/jawa634/superfl ... 20ocr).pdf
& This you can make the picture larger
http://www.assurich.com.my/Engine-Dynam ... 10-120.htm
Hope this helps you
Hope this helps you
Re: Flow ranges
Corrected link for Superflow 110 manual: http://www.freewebs.com/jawa634/superfl ... 20ocr).pdf
Re: Flow ranges
Thanks for the help, men!
This bench I borrowed is actually a SF100, very old, I guess.
The inclined manometer is NOT in percent of total.
It goes from 0 - 3 inches by .02 increments.
Would the 3.0 inch item be 100%?
The scale looks to be about the same overall length as the SF110 I used to have...
sbm
sbm
Re: Flow ranges
In all likelihood yes.sbm wrote: Would the 3.0 inch item be 100%?
BTW, the formula to convert pressure difference Δp to percentage is √(Δp/p) where p is equal Δp at 100%.
And for a bench of that type, you'll also need to apply the temperature correction factor as described on page 8 of the manual.
Re: SF100 Flow ranges
Is this the graph you wanted ?sbm wrote:I had a Superflow 110 for 38 years and just sold it. Had to borrow another while waiting for the build up.
sbm
neil
Thanks for the graph.
Problem is: that old SF100 would draw enough pressure to do much testing. On a 2" valve, it wouldn't quite see 5".
So I borrowed my old SF110 back.
But-
The new owner must have worn out the motors, because it runs hot and smells like rosin core solder!
One prob after another.
Same as always...
Looking to borrow another 110...
But-
Same as always...
Hi guys
Does anyone have a higher res version of this graph?
I'm mainly looking for what orifice combination at what flow
Thanks in advance
Thanks in advance
Welcome to the forum!
If you search Google for "superflow flow bench manual pdf" you can find what you are looking.
I prefer not to post the actual link here as it's not from an official site
Thanks Bruce.
I'm now thinking that instead of building a Superflow 110 style bench I will probably just buy your stuff and build an electronic version traight up.
I have a 2" inclined mano already which is why I was thinking that way, however we have a training business and I'll eventually build about 10 benches so your system might actually work out more ideal.
I also have the equipment (Faro 6 axis digitising arm) to digitise ports. Our goal is to eventually teach digitising, modelling(CAD) and CFD testing as a "digital flownench) followed by CAM/CNC machining of the ports.
We'll need actual flowbenches for the students to compare and check their results. I'm still researching the best way to achieve reasonable results without spending a fortune.
We'll be training on a simple air cooled 2 valve single cylinder head.
Because we can digitise ports very accurately and quickly, we can also 3d print the ports either for testing or casting aluminium test ports/combustion chamber/gasket surface.
Sorry if I just bored you to tears....lol
www.formulastudent.edu.au
Nothing about the engine stuff there yet. We still need to apply to get it on scope as we do nationally recognised training here in Australia.
Currently it just has our racecar chassis building program called Formula High School.
Cheers
Greig
Cheers
Greig
