I'm currently undertaking a project at Brooklands college which involves the use of their SF 110 flow bench. However it seems as though the inclined manometer isn't functioning atm. I'll go through what I have done and hopefully someone will tell me that I've done something wrong and everything will be tickety boo.
-I have installed the calibration plate
-All stoppers are in leaving the #1 hole open.
-Fan set to intake, both flow control knobs closed.
-Larger test hole covered leaving 0.312" hole open.
-Once on I set test pressure to 10". The inclined flow meter moves less than 1mm, if that.
I've tested it across 3 days. Interestingly it did work first thing on the second day, I then took the flow back to 0 and switched it off, only to find that it didn't work again directly after that. It is probable that some delinquent has been playing with it and caused the fluid to bubble over etc. Could this problem be down to a blockage/split pipe somewhere along the line?
Another question, this flow bench has a small panel/monitor at the top right, with various tubes heading in and out. Are there any components in this which could cause this kind of temperamental behaviour?
Thank you.
