I have the phase angle controller and a SSR wired to the hot of one of the 220 legs and from the SSR to one of the 3 wires of the 220 motors ( yes they are 220 lol) the other hot runs from the contractor to the motors other input connection and then the ground wire is hooked to ground.
When I power it up the phase angle controller lights up and as I adjust the 1k pot the light goes brighter and dimmer until it goes off. If I measure the output of the SSR to ground I read 120 volts and if I read across the 2 hits I read zero with them hooked up to the motors when not hooked up they read 246.
I get no motor spin sometimes when I flip the switch the motors have a slight spin maybe 2-3 revs that's it.
Now if I remove the SSR and phase angle controller and I run both hots straight from the contractor to the motor connections the motor spins full speed.
I did not buy the relay or the phase angle controller from Bruce but I did buy the same phase angle controller he sells but have a Amazon SSR ( I know I know it will get replaced soon enough ).
When I read the dc output on the phase angle controller it only goes up to around 11.5 volts with the pot all the way up so it has a range of 0-11.5 with a 1k pot I believe it's suppose to output 24volts.
If anyone can help maybe I'm missing something simple.
I do remember when testing the SSR at work with a 40 volt power supply set from 5-25 volts the SSR didn't want to trip until higher in the voltage range and some times it would flip on off on off on off real fast and I noticed when at 24 volts it worked but I noticed if I turned the power supply on and off sometimes when I came on the SSR didn't want to switch on or took a little time a couple seconds.
I was just using a basic fluke DMM across the outputs when testing the SSR at work.
I also measured across the SSR when on and read 45k ohms which made think something was wrong but reading online says that's normal if reading with a DMM in the ohms setting.
The whole system is wired exactly like the plans show page 28 220 all motor schematic.
Here is a link to the motor spec sheet for the motors I have they are 3 wire 220 volt black white and green ( green is ground on the chassis of the motor)
https://www.ametekdfs.com/-/media/amete ... 6fa2156175
If anyone can get me running I would appreciate it.
