Air and water density spreadsheet, MS Excel 97-2003 format
Place to add formulas. If you post a formula please make sure your abbreviations are spelled out so it avoids a lot of follow-up postings. I know a lot of abbreviations are common or taken to be common knowledge. Please be sure to checkout the new FAQ of common abbreviations.
Please post formulas in separate topics, do not add formulas to someone else's post unless it relates to the original post. Also in the topic line make a note of what your posted formula is about . Thanks
pcnsd
Post by pcnsd »
I put this together to use with the FlowSoft basic configuration program.
It is in imperial units. The sheet is protected but there is no password if you wish to play. The water density equation uses temperature only as an input. The pressure variable is insignificant in practical effect for our use.
Regards,
Paul
AirWater Density.xls
pcnsd
Re: Air and water density spreadsheet, MS Excel 97-2003 form
Post by pcnsd »
Sorry, I found a conversion error in part of the water density equation in the above spreadsheet. This one is corrected.
AirWater Density corrected.xls
Hotz
Post by Hotz »
Thanks for sharing.......
Hotz wrote:Thanks for sharing.......
I'll second that . . . thanks for sharing!
