Play-doh
Luv.guy
Play-doh
Post by Luv.guy »
Hello,
I have been testing Harley heads and have attempted to use play-duh from Walmart to make a velocity radius around the port but at .250 or so lift at 28@ the air will suck the play-duh down the port 😂. Anybody have any advice?
coulterracn
Re: Play-doh
Post by coulterracn »
Try modeling clay
Luv.guy
Re: Play-doh
Post by Luv.guy »
I will give it a try. Thanks
Re: Play-doh
A better more consistent way would be to make yourself a radius intake plate that precisely matches the intake port shape and location.
The easy way to do this is to get a piece of fine grained hardwood about an inch thick and drill a hole slightly less in diameter than the intake port, but large enough for the small end of the cutter to enter into the port.
Bolt this over the port.
Then use a radius cutter in your router to produce a beautiful smooth accurate bell mouth that leads perfectly into the port without any step.
The clever thing about this, is that the small ball bearing on the end of the cutter follows the exact profile of the port entry and your bell mouth matches up perfectly. The port need not be round, but can be oval or rectangular and it produces a perfect radiused entry every time.
Something like this perhaps:
https://www.amazon.com.au/Radius-Roundo ... 0142&psc=1
Luv.guy
Re: Play-doh
Post by Luv.guy »
Thanks Tony, Something like your talking about is the route I'm going to go. I tried some clay and while I was looking at the depression on the computer the clay disappeared :lol:
Re: Play-doh
Once you have a router and a suitable radius cutter, it only takes a couple of minutes to make one of these up.
Its even better with a multi cylinder head, as a whole row of ports can all be done together.
Murphy
Re: Play-doh
Post by Murphy »
I love my HD head exploring and modifications.
I tried that clay approach and said heck with it. I have a spare manifold that i use for checking gain loss of modifications, my idea was its the real world
Re: Play-doh
Welcome to the Forum Murphy !
