Hi man,don't think I'm a slightly mad.....
wath do you think to use an alternative piston vacuum source?
I have some car's engine in my shop,4,6,12 cilinder.....
I think: if I took a 2-3 liter displacement engine,remove the cylinder head,replace it with a very thick plate with reed steel valve,a couple for each cylinder,like a workshop compressor, and ran this device with high power electric motor,I can create a good depression for a workbench?
alyternative movement vacuum source
Sorry for my English!
www.brandoracing.it
Alfa Romeo 75 owner
www.brandoracing.it
Alfa Romeo 75 owner
Re: alyternative movement vacuum source
Hey man,no-one respond?
Idea?
Opinions?
You can insult me!
Idea?
Opinions?
You can insult me!
www.brandoracing.it
Alfa Romeo 75 owner
www.brandoracing.it
Alfa Romeo 75 owner
I've seen engines converted to become air compressors but I don't think they produce enough air volume to be used as a flowbench air source.
Thanks Ray,do you think the problem is the cfm and not the h2o depression?
at the end,For 2 litres Engine,@ 3000 rpm made 6000 l\min, 6cubic meter is about 210 cfm.....
www.brandoracing.it
Alfa Romeo 75 owner
www.brandoracing.it
Alfa Romeo 75 owner
Piston compressors are at their best at very high pressures and low flow.
Something like a roots blower would be a much better and more efficient way to "mechanically" compress air.
But a centrifugal blower has the most advantages, and fewest disadvantages for a flow bench.
Among the advantages are small size, steady non pulsing airflow, and potentially quite high efficiency.
What would be perfect, would be a flow bench blower that always generates the same exact test pressure at any flow without needing any extra control system.
And a centrifugal comes closest to that ideal.
